V
Vigilante
Gear nut
Hey fellas, very simple recording problem I need some ideas, tips on.
Here is the deal, I've got a decent condenser mic and I'm recording through a Tascam US-122 to my laptop. I recorded a person singing and playing guitar. The condenser was pointed in the general direction of his mouth, and I had the guitar pickup going into the Tascam as well to channel 2. I'm sure the condenser picked up the guitar quite a bit as well. Although his guitar sound hole was plugged, muted.
The recording sounded great as it pertains to the quality of voice and instrument, I recorded with Cubase LE.
Now then, when I saved the file as WAV and played it back through my home stereo through my laptop's 1/8" headphone jack to my stereo's aux input, I noticed two things:
1- The recording must have been fairly quiet. When the laptop's output was max'd, I had my stereo at volume 23 I think. When I play a loud movie I have it at maybe 14. So for some reason the recording is really quiet, or it has to do with how I'm going about playback, not sure.
2- Because the volume is pumped up to hear it, you also hear a thundrous amout of background noise, I don't know what to call it, a dead air recording, hiss, whatever. I'm sure this is because I don't have a recording booth and the condeser is picking up air noise or whatever.
So what can I do, or check, to prevent these two problems? And can I run the recording through some kind of filter to remove the background hiss? Or is the hiss just because I'm outputting through powered headphone jack instead of line level? I don't know. Can I up the volume to something normal with losing quality? How do I even know what a normal volume IS in the first place to raise a recording to? Does the hiss have to do with compression/recording quality of the WAV? I think it was sampling at the defaults of Cubase which I thought I saw was 44,000hz? What should I record at? How do I control the recorded volume without clipping?
Sorry for all the questions, believe me, I've searched for tutorials on Cubase, and I just don't get it. I can't even get cubase to play within the program, I have to export to wav to hear anything. And if I record a 2nd track, it only ever exports the top track. So I cannot figure out Cubase.
So please just give whatever pointers/tips you can to help me get started.
You guys helped me buy this stuff, so don't leave me when I'm trying to figure out how to use it! lol.
Thanks for the advice.
