what the numbers represent in the mixer configuration?
  • Thread starter Thread starter musicmanmiket
I have a 1 track mind but it still gets the job done
Yo Musicman! Don't you hate it when people blow off your honest questions? Generally the numbers indicate the number of tracks, and the number of busses. Therefore, a 12/4 mixer has 12 available tracks that can be configured in any combination to come out of 4 outputs, or "busses" Whether you need a lot of tracks or a lot of busses depends on what you are recording and what you need to do with the tracks. Once you have combined 2 or more tracks into a single buss, you better have gotten it right, because you can't separate them again. If you are recording through a mixer into a soundcard with only 2 inputs (stereo), then you would normally only be using 2 busses. However, additional tracks and busses can be used to send selected signals through effects chains, to create custom headphone mixes, for re-amping, lots of stuff. The more you learn about processing tracks, the more uses you'll find for extra tracks and busses.
Here's the problem- The more tracks you have, the lower the quality is per dollar. Sometimes, 2 damn good tracks are better than 64 that suck. Most good home studios have a few really badass channels that get used most of the time, and a bunch more that are "OK" for when you need a lot of tracks. Drums in particular suck up lots of tracks. Also, the more places you need to send tracks for processing, and the more mics you stick on a source, the more tracks you need. Personally, I am a minimalist, which means I don't use nearly as many tracks as a lot of guys, but I don't want any of them to be combined with any other track until I'm ready for mixdown. That way, if I don't like my mix, I get to just do it again until I'm happy with it. Lot's of engineers think nothing of using 64 tracks or more. I have no use for more than 18, but I want 18 competely separate tracks. I'm in the minority there, and most engineers will use lots more tracks than me.-Richie
