cellardweller
I've read about the how it is done, but what is the resulting change of sound? Increase in gain... what???
cellardweller said:*EDIT* do both halves of the humbucker work when it is "tapped" or only one?
Sounds interesting.. I don't think I've ever heard of that on a guitar before.Gonny said:I thought coil tapping was something altogether different than single/double coil switching that Phyl described. My understanding is that coil tapping is where there are two different outputs from the pickup winding - one taken at the end of the coil and one taken (tapped) from somewhere in the middle of the winding....
Gonny said:I thought coil tapping was something altogether different than single/double coil switching that Phyl described. My understanding is that coil tapping is where there are two different outputs from the pickup winding - one taken at the end of the coil and one taken (tapped) from somewhere in the middle of the winding. This effectively gives you the ability to switch between two different numbers of coil windings. Not quite sure what it's implications are on tone (just knowing that higher impedence pickups tend to be louder, I'm guessing the fewer winding option would be quieter and clearer in tone).
I would like to retract this statement totally at this pointcellardweller said:I've read about the how it is done, but what is the resulting change of sound? Increase in gain... what???
Gonny said:I could be wrong on that definition of coil tapping. It's something I remember from waaaayyyyy back, and my memory's hazy. I always heard of single/double coil operation as just that...single/double coil switching. hmmm.....
Gonny said:Phyl - perhaps I'm not explaining it very well. What you're talking about (single/double coil switching) is basically shorting out one coil of a humbucker to give you a single coil pickup. What I'm talking about could be done with a single coil pickup.
You have the start to your coil as one lead from the pickup. You wind it some, send a lead out from there (the coil "tap"), and the wind it to the end. You can set up a switch to pick which output you want to use - the one from the middle of the coil or the one from the fully wound coil. You're effectively picking between two different numbers of windings on the same coil.
Again, maybe my memory is failing me here.
Phyl said:I think you're right, the correct terminology for the application we're referring to is coil splitting. Coil tapping is the more generic practice of trying to pick out differing amounts of signal from coil.
metalhead28 said:I thought I would make the point that most production guitars that I see with a coil split switch call it a coil "tap" switch, but splitting is really what they are doing. Basically using only one coil of a humbucker to get a more "strat" type of sound. Expect more noise, less output, and more articulate sound (strat) when tapped/split.
