R
rtimms
Hello,
First off i do not have any knowledge of microphone.
I currently have a YouTube channel and doing commentary. I want to improve the capture i am using the sennheiser 360 headset mic to capture the commentary and i am having to edit the audio and quailty is not the best.
I don't mind spending money to get the a good quality recording. Currently i have a very good sound card its the Asus Xonar Phoebus (stats at the bottom)
Option-1 - 3.5mm mic and using sound card.
Option-2 - Get a blue yeti via USB
Option-3 - Get the blue yeti Pro and convert the XL adapter to a 3.5mm, i am Not sure if this will work or there is a point
If option one is the one to go for can you make some recommendations of mics to go for i have background noise sometimes when the air con is on but i can edit the audio if need be.
Thanks for you help
Analog Playback Sample Rate and Resolution :
44.1K/48K/88.2K/96K/176.4K/192KHz @ 16bit/24bit
Analog Recording Sample Rate and Resolution :
S/PDIF Digital Output :
S/PDIF Digital Input :
ASIO 2.2 Driver Support :
44.1K/48K/88.2K/96K/176.4K/192KHz @ 16bit/24bit with very low latency
Thanks for you help
