What likely is my problem?
  • Thread starter Thread starter Trumpspade
Trumpspade
Trumpspade
I'M BLESSED.......
When software tends to skip or hesitate a bit, what likely is the problem? I am running Reason 2.0 and sometimes when I am playing something that I have created it'll skip a time or two during the whole session........
I have a gateway, 512ram, 40G hardrive, audiophile 2496 installed I need to fix this ASAP, I have a deadline to make!!!
Trizza
Could be too slow a computer, could be a cracked version of software, could be compatibility issues, and so forth. Use the customer support for the software and see what the technicians think it might be
If it skips in the same place every time, chances are it's been recorded like that.
If the skips occur randomly, then it's most likely a shortage of buffers and your cpu is unable to keep them refreshed fast enough.
You should be able to specify the number of buffers required somewhere in Reason. Just increase the number slightly
What I had was random stuttering ................
And you were right Bulls hit, I had to expand my buffering. I haven't had the problem since, Thanks I really appreciate it!!!!!!
Trizza
