salida
I have noticed that some 16-track tapemachines use 1/2-inch tapes and other 16-track tapemachines use 1-inch tapes. What exactly is the difference?
salida said:Ok. does that mean that you must have at least 2-inch tapes to make pro recordings? Or do the smaller tapes sound good too?
Which sizes can a Fostex b-16 use?
jpmorris said:Depends what decade you live in. 2" 16-track was used on 'Dark Side of the Moon' and lots of other albums from that era. It was a natural extension of 1" 8-track which was introduced in the mid-60s and used on things like 'Court of the Crimson King', 'In A Gadda-Da-Vida', 'Atom Heart Mother' and some of the very early Genesis albums, I think. If I was overflowing with money, I'd get one of these myself. You don't need noise reduction with this format.
"Scholz's basement laboratory is not a showplace of new high-tech gear, because Tom is no fan of digital equipment: "Anyplace you've got a microprocessor, you've got a disaster waiting to happen. I avoid them like the plague." This means analog tools wherever they work. The main multitrackers are two 3M M-79s, which Scholz uses to dupe his masters so he can wear out the copy. There's also a couple of Studers, his first Scully 12-track, and a Scully mixdown deck for mastering. This last is equipped with a special meter to precisely set the high frequency bias tone so he can take advantage of a notch in the signal-to-noise characteristics of Scotch 226 tape; this gives him exceptional low-noise, big headroom master mixes.
Incredibly, most of his recordings are fourth generation, which he gets away with by plenty of masking and gating. To sync his big decks together, Scholz tried an expensive SMPTE synchronizer, but found it had too much wow; now he syncs up by putting each deck on a side of his headphones and slowing the reel down with his hands so the sound is in the center of his head. His method of punching in and out is similarly low-tech: a bent coathanger to simultaneously hit the play and record buttons with his toe."
Musician Magazine, JAN 1987
I'm not intimately familiar with the 001 but, if you're having problems with capturing dynamics, that is a problem that could migrate along with your change over to analog in that minding your levels and making proper use of compression is an engineering skill that is applicable to both disciplines.I´m lacking a bit of punch in my recordings. It´s like there´s more output to pro recordings and I´m guessing that it is due to bad converting from the digi001.
Come on now, you didn't say WHICH desert.The Ghost of FM said:I'm not intimately familiar with the 001 but, if you're having problems with capturing dynamics, that is a problem that could migrate along with your change over to analog in that minding your levels and making proper use of compression is an engineering skill that is applicable to both disciplines.
Recording to analog will give you more headroom without noticeable clipping on wider format tape machines and especially so on those that do not apply noise reduction like dbx that allow for traditional analog soft clipping into the upper signal levels above 0vu on the meters but, if you're not careful, you can still screw up your punch and dynamics by not adjusting your compressor settings and recording levels.
Switching to analog should be done by those who are craving the sonic character that true analog can bring in terms of the unique frequency response curves that vary from machine to machine along with their thicker sound canvas that captures more detail at the higher end formats of track width and speed. It can also be a far reliable format of archiving your recording for lifetime access without running into the current problems of digital formats which can change like the weather and leave you and your data files like a beggar in the desert.
Cheers!![]()
Why, the desert of your mind, of course!monty said:Come on now, you didn't say WHICH desert.![]()
salida said:I love the drum sound on Primus "the brown album" it was recorded onto tape by Les Claypool "the bassplayer" himself and mixed to. It has the punch of any pro record on every instrument...
EDAN said:Interesting side note; Everything on "Dark Side" was second generation. As far as 1/2 goes, Boston's first album was done on a TSR-8. I suspect there was a lot of high end outboard gear used as well, but still it goes to show that a pro album can be, at least in part, recorded on a recorder that for the most part was intended for the home market.
