I
IronWine
Member
So i got into analog recording in the past few months..i'm slowly learning it while doing my bachelor of sound engineering.
I'm using both the tascam 234L and the akai mg614. Both are amazing pieces of gear.
A question came in my mind while i was testing the sound of my recordings at different speeds (1 7/8, 3 3/4), which i have noticed that has a limited effect on sound "quality" to my ears. I read that it should have an affect on higher freqs and general fidelity.
Considering the fact, or my desire, of eventually realeasing music on cassettes(with a digital pack tho), these realeses would obiously be of normal speed cassettes for normal tape decks...then..what is the purpose of initially record music at double speed? The music will eventually end up at normal speed sometime in the mixing proccess.
If the music is being transfered to digital i would assume that there is an advantage for the higher speed taping. But for the "80'-90' " mindset..times when music was consumed vastly on cassettes, and all-analog recording proccess was somewhat common, what was the notion behind marketing double speed fourtracks? Pure marketing purposes only maybe?
Cheers
this forum is a gem for me! And for all analog lovers.
Cheers
