What in the actual hell is going on over at Band Lab?
  • Thread starter Thread starter fuzzsniffvoyage
fuzzsniffvoyage
fuzzsniffvoyage
The Bandlab Assistant will not load. It will not re-install. And worst of all Sonar is not working........any previous version I've purchased. Keep getting the same errors on all.
1st:
Unable to open audio playback device. Device may not support the current project's audio formant or may be in use.
For help, please visit:
Cakewalk Support Home
or contact Cakewalk Technical Support.
2nd:
User privileges insufficient to start a low level driver...
Started getting the 2nd error message a few weeks ago in SPLAT, that's why I finally downloaded BandLabs version.
Nothing major has changed. I did have to change the settings in my Tascam US-1800 to work with PT's, but I changed it back for Sonar.
It's not my internet connection, obviously. I'm here. When I ping the link above in the error message, it times out, no connection. For the last 3 days.
Now I am able to export project stems and load them in to Pro Tools 11. Just can't record or play back.
Any Help or suggestions would be greatly appreciated. Thanks.
1st:
2nd:
Sorry, I'm not having any issues whatsoever with either Assistant or Sonar. Did you see issues right after you changed your Tascam settings? You might try uninstalling, rebooting and then re-installing the Tascam driver.
Got the playback working. Went into settings and seen that the 11 rack was enabled as a sound card, as was the motherboard sound. Still not able to connect to band lab web site and assistant not loading.
The user privilege was screwy because I logged in on pc as a guest.
