Rick,
> The catch here is "NOT built properly" vs "properly built". <
Yes, but all I meant is having the right amount of damping inside the trap. It's not like someone shaves 1/32 inch too much off a side rail and all of a sudden the panel starts ringing. It's not difficult to build these correctly!
> IF I understand the point of Membrane absorpters correctly, as they are NOT broadband. <
I consider the membrane bass traps in my
Plans article to be broadband, at least in comparison to a Helmholtz design that is often made to have a very narrow bandwidth to target a single mode. Each membrane trap type absorbs over a useful range of about one octave. More to the point, the
system of traps described in my article is broadband because together they work over much/most of the bass range. So while they're not broadband in the sense that rigid fiberglass is, they're not really "narrow band" either.
> more than one OTHER expert has posted the possibility of "doing more harm than good" on other forums. Including a Physicist. <
To my knowledge only one person has ever suggested that membrane bass traps can do more harm than good. And as far as I know that fellow is not a degreed physicist, though I can't be certain because he never reveals his credentials. What I am certain of is his motive, even going so far as to make up stupid stories about membrane bass traps doing more harm than good if there's a chance it will make me look bad. Think about that.
Last time I checked Alton Everest was still alive. You might send him a letter asking if the membrane bass traps described in his book do more harm than good. Likewise, you could email the BBC who has done extensive research on bass trap types and, as far as I know, never concluded that membrane traps are a poor choice.
--Ethan
