junplugged
Taking the slow road
just wondering, some mics have flat, rolloff, or pad. -10
Phosphene said:If the preamp is clipping, just turn it down.
punkin said:Exactly...use the pad to attenuate (decrease) the level of signal going to the preamp. Drums would be a perfect example but only if/when the preamp is pushed into clipping.
junplugged said:i use it to give more sound of the preamp than the mic
i know, me neither, then about 2 days ago, i was sitting here contemplating the fact that when i'm using balanced line, i don't need to push the pre as much b/c of the little increase in levels, and the corresponding ratio to the meter on the pre and the mixer, and i was thinking about how it might be less pre sound b/c of that lower setting on it...it's just a theory, but anyway, i decided to try it.Erockrazor said:I never thought of that but that would be a good way to compare the color of a given preamp. I would like to see a mic with more than one pad to take off ALOT of dB's and see how much you can make the preamp stick out. Interesting thought. Ive never thought of that.![]()
chance said:Pads on microphones attenuate the signal going thru the mics electronics.
