What do I need?
  • Thread starter Thread starter noisedude
Woah! It's cool man! I know the limitations of my gear ... I only recently got that M12 and only then because a deal came up off the back of an ebay auction. It'll be fine for drumkit stuff as long as I have at least two quality pres available (and preferably four, as you say) for critical parts.
What you're suggesting is exactly what I'm saying - I don't want to keep dropping my leftover overdraft (!) on something that I can just about afford every time I get a little spare. I have a decent enough platform to start from here, better than most home recordists will ever put together. If I was to get to your standard then I'd be able to charge a good rate because my equipment would be better than most of the commercial studios in my area!
Chess - I kinda agree with you. I'm not going to blow a tonne of money on something out of my league, but I might keep a list of wishes tacked to my pinboard and make sure I check ebay regularly. The discipline is only getting the stuff I should aspire to now, though.
So, both of you guys are suggesting that I don't go and augment my cheap gear with slightly less cheap gear then? I could go out tomorrow and add SPs, ADKs and cheap rack gear with no problem. Are the kinda pieces we discussed here the next sensible step, or should I keep inching? I guess that's the real question here ... what will benefit me the most where time is no object?
noisedude said:
Harold - it's ok, it's either an IRQ conflict or a PCI bus latency issue. The PC itself is a 2500+ Barton core Athlon machine - not about to set the gaming world on fire but with DDR400 it flies for music - 2.6ms latency ... kiss my chuddies ;)
I know is outside the scope of this discussion. But what exactly is the problem you are running into? What OS do you have, and what are the symptoms that you are seeing. You mention PCI or IRQ is that from your Delta 44 and if not then what else you got in there (other than a modem or NIC)?
Yo - this is my main thread on it, but search under my name and some PC-related swearwords and you'll find I've jabbered about it all over the place ;)
Noisedude - Are You Bidding On A Autocom On Ebay. Id A Sold You Mine :)
Not at the moment!!! I've looked at one or two in the past but I won't spend any proper money on 2nd-hand Behringer stuff.
Holy crap you're right! Shit!! I don't remember bidding for that!!!
This is what happens when I stay up late with the PC on :(:(:(:(
Dammit this thing ends in five minutes. I can't be doing with this!
Ha! Some chump took me out at the post. Excellent.
Back to a proper thread now, still waiting for Richie and chess' replies.
