A
Ally-007
Member
So I have a Sonicake Matribox multi-FX guitar pedal, that is generally well-regarded. Unfortunately, I often hear a crackle, momentarily at some higher peaks of the waveform, when using some effects combinations. It looks like it shouldn't be happening, because the level warning lights on my audio interface (Behringer UMC202HD) are not lighting up. So I'm guessing that some other part of the cirquitry chain is getting overloaded, momentarily, at those waveform peaks. I can sometimes get rid of it by carefully messing about with the gain staging of the effects modules in use in the pedal. But that can be time consuming, and often results in way less overall gain than what I need. Switching from 'instrument' to 'line' level input (or vice-versa) on the interface can also help, sometimes. Can anyone provide any insight into what causes this issue? Normal clipping, (caused, say, by increasing the gain control on an amp module or a boost/distortion module) just manifests as normal guitar distortion... but this is something more; I hear a momentary crackle/interference, at the loudest peaks, that can really mess up a recording, especiall when the guitar sound needs to be undistorted. Any insights would be much appreciated.
