M
Mongoo
I'm trying to figure out what I want. A Digital Multitrack or a Computer based multitrack.
I asked about this else where and some one said they would get the computer one because other wise you can not bypass the pre amps of the recorder. What are pre amps?
What I really need is a digital recorder that will record a ablolute minimum of 8 tracks at the same time. I "THINK" I want as many xlr connections as possible. Some recorders I've looked at don't give you that many. Instead they give you balanced TRS connections. What can you do with "balanced TRS connections"?
If I need to record a drum set can I do that with "balanced TRS conections"? Would it be the same as useing XLR's? And where do Pre-amps and phantom power fit into all of this? Needless to say I'm confused.
I hate to make this even more confusing but I was told you could get a computer and hook up conections and a mixing board to it. That would work to edit sound going it on the first take but wouldn't it be impossible to edit the music with the nobs and stuff post recording? My reason to go the non computer route with all of this is to have tangable adjusters.
Anyways. I appreciate all of your help. Thanks in advance.
Mongoo
Mongoo
