What are normal tv mix settings?
  • Thread starter Thread starter NYMorningstar
N
NYMorningstar
Recording Modus Operandi
I know there are a few tv buffs here that mix and edit for television. Can you tell us a little on how you do it? How is it different from mixing for audio only? What do you use for monitoring? A tv? Do you normalize? What's the RMS lvl you shoot for? Do you eq differently? Thanks for sharing!
The only major difference is you really want to check for mono and surround compatability to make sure nothing weird or unexpected is going to happen. Most lower budget film/tv productions are pretty clueless when it comes to audio so they are usually happy with anything that sounds half decent. Generally you probably want to go for a little less dynamics then usual. That helps the music sit in the mix and not overwhelm the dialog or sound effects.
Larger budget productions may have more specific requirements but they usually have their own people doing the final mix anyway and they can do extra EQ or dynamic adjustments then.
Just be glad you don't have to try and shoehorn the music into an optical track on a film print. That was like mastering for telephone.
