What about Fleece to cover 703
  • Thread starter Thread starter ds21
D
ds21
With all the colors you can get in fleece nowadays could this be used to cover 703, or would it cut down on the absorption factor too much? it doesn't seem like it would, maybe wrong...
I would think it would reflect a lot of highs as apposed to burlap. Burlap is just such a loose weave.
Fleece is going to cost quite a bit more.
What I do to get a generial idea of the audio transparancy of a material, hold it up to the light. If you see through it easily, it is going to pass audio easily.
Also try blowing through it. If you can blow through it it will also pass audio.
None of those methods put into account the reflectiveness of the material itself. ANd they're not scientifically proven.
I chose felt to cover my 703.
You can get burlap in DOZENS of colors(even lime green and pink), one should be close to what you need.
I'll have to look into it, I just always think of the basic grey, tan or that burnt orange when I think burlap
Mine is stripe patter. Just go to a fabric store and start pulling fabrics off the shelf. If it is thin enough and you like it, go for it! Could be burlap, could be muslin, could be silk, etc.
best pak company has burlap in assorted colors and fairly cheap too. Google it.
felt is also a good cheap choice.
To play it really safe you should also invest in some spray-on flameproofing
Double Weave
During forays into learnong about restoring my old speakers, (B&W, Thiel, Time Windows, etc) I was told by several sources that any double weave is sonically transparent.
Fleece is not a double weave, but then I guess burlap isnt either...
Oh well, just thinking aloud again.
Is it my imagination, or does everything listed in this thread catch fire really easily and burn like crazy??
Most things in my house do
Unless you know that you are dealing with flameproofed material it is always best to buy some spray-on flameproofing.
That being said a fabric covered fiberglass panel is much safer than cheap foam on the walls because the fiberglass itself does not burn.
Don't get caught up in what kind of weave it is. Blow through it. If it puts up virtually no resistance it will do the job. It isn't a matter of the type of weave by how tight it is.
