mshilarious
Banned
I am actually, not the only one who is "current hungry". I remember reading Josephson proposing a new standard for phantom power of total 43ma available, with 2.2K resistors, each (of course, in this case all the Schoeps circuits will need to be re-worked).
Gus also posted about external PSU. While (I think) his ideas are somewhat different from mine, the bottom line, the external PSU would give quite a bit more flexibility in the design and open room for new topologies and design solutions, impossible for the current P48 standard.
Well it's an idea, it just seems like it would make a bit of a mess to me. Already we have scores of noncompliant P48 gear on the market. I'd like to see AES develop an enforcement mechanism, say a voluntary testing procedure and an official logo or something. Not just P48, but why not VU=dBFS standard, among others?
I confess I don't get the need for extra power; isn't the noise limitation ultimately the FET? If you parallel a bunch of FETs to improve noise performance, don't you also increase input capacitance? This confuses me
Ah, I'm a small-capsule guy, any run-of-the-mill 3nV FET will do . . .
Well, at least they saved about $0.40 for an additional pair of BJTs, pair condensers, and couple resistors, which would take care of all the drawbacks of such topology. What a marvel of engineering approach!!!
Which FETs do they use?
I don't know, never seen one, I actually just gleaned that from their manual. They have a graph of gain according to load impedance, and doing the math it works out to 6k8 "source" impedance. What else could it be? Even if it's something different, the effect is apparently the same.
I will give away my latest find to DIY types: if you want to do an inline amp, use ADA4841-2. That thing is sexy, and it's going in my latest design. 1.1mA per channel, 2.1nV/rtHz, 12V/usec. Supply is limited to 12V, but do as I'm doing and use it as the front end to an instrumentation amp topology. That yields headroom of +16dBV, should be plenty for a mere 20dB of gain. Heck, make it 30dB. You're using this thing with a ribbon, right?
Guys, would it be reasonable to deduce that a "slower" response microphone tranducer,
ala a dynamic (or ribbon/subset), would help to mitigate this distortion vs. a condenser?
Aliasing distortion? Well you have to understand that no modern converter should have that problem, they all have adequate anti-aliasing filters. So it shouldn't matter what your analog signal source looks like.
The problem arises with subpar digital processing where designers have not considered that their plug generates ultrasonic content that needs filtration (which has to be done with upsampling, filtration, and then downsampling).
The quick fix for a plug you love but it aliases is to run at 96kHz and use a good SRC back to 44.1kHz . . . according to the SRC's filter quality, the aliasing distortion should be driven down -100dB below signal.
(FWIW highly respect the skillset of those like yourself posting here)
