K
Kerfoot32
I'm in a flimsy hand built shed. I insulated the walls and ceiling with fluffy fiberglass and covered it all in pegboard. It's sounding cool so far. But I'm trying to make a game plan for my bass traps and rfz. I'm using rigid fiberglass of course.
Should I use 705 for everything, or just the corners? Or will 703 do? Is FRK necessary? It's a small room (8x12ish) so I don't want it to be too dead. Will I run the risk of it being too dead if I do all the corners in a room that small? If so is frk the solution?
I was planning on making the corner traps 4 inches thick. Do the rfz panels need to be that thick too? And exactly how many corners do I have? Do those wide angles where the wall meets the side of the ceiling count as corners?
Thanks!
