Waves wont load
  • Thread starter Thread starter Petrenj
P
Petrenj
Hello friends!
I have a following problem.No one from waves plug-ins will not load in my reaper daw.
It s more annoying because it already doing great without any problems.
Any hints?
...well, let's see where it goes. I wasn't so much making any accusations as I was trying to solve his problem, simply because it's possible that cracked software won't load.
is "it" the waves software, or is "it" reaper, or is "it" waves in reaper?
so waves wont' work in reaper?
if they won't show up in the list of plugins, you probably don't have the folder they're in selected in reaper. Go to preferences in reaper->vst->select the folder the waves plugs are in.
if the waves plugs are showing up in the fx window but not loading or working, try deleting the folder from reaper and reloading it.
even demos should work.
None of it.Theres no waves plug ins in no other daw software.It goes instaled but simple cannot be reveal by software.
If its the demo version, it probably is not set up to be used as a plug-in!
