John Sayers
Solar Power!!
I've been reading a lot of pages on wall treatment discussion and it's good to see that people are starting to understand the absorption coefficients and their relation to frequency response. As you've now recognised the rigid fibreglass is much more effective than the regular acoustic foams.
If you look at the formula for the RT60 (Reverberation Time) of a room it goes like this:
RT60 = k(V/Sa)
k is a constant that equals 0.161 when the units of measurement are expressed in meters and 0.049 when units are expressed in feet.
Sa is the total surface absorption of a room expressed in sabins. It is a sum of all the surface areas in the room multiplied by their respective absorption coefficients. The absorption coefficients express the absorption factor of materials at given frequencies.
V is the volume of the room.
The Sa figure is very important to the outcome. In other words how much treatment you actually have on the surface area of the room.
A 10' x 10' x 10' room has a total surface area of 600 sq ft (4 x walls, ceiling and floor) so if we apply 24, 1' x 1' foam panels we have only changed 24 sq ft of the surface area or 4%. Treating one whole wall will only effect 16% of the surface area.
My point is that you really need to treat whole walls to really change the RT60 of a room to any effective degree.
cheers
John
RT60 = k(V/Sa)
cheers
John
