Wall mount for PC cables for vocal booth
  • Thread starter Thread starter JoelNesv
J
JoelNesv
Hey, I'm building a vocal booth to record VOs and was curious if anyone knew how to get a wall mount for PC cables? This probably isnt ever done, but I want it so that I can have my mic and preamps in the booth, along with my computer monitor, keyboard and mouse, and then have the PC outside the booth to avoid the noise. Is there a way I can have computer cables going through the wall without compromising the sound isolation??
Thanks!
Not sure this will help, but as far as wall mount plates go, if you can't find one in the configuration you desire it might be possible to have one made custom from Markertek.com
http://www.markertek.com/custom.asp
But you could probally make one yourself as well.
I had the same scenerio ( a voice over booth). I set up my system like this.
1) PIII 650 sitting right outside the booth. I ran a USB cable and VGA cable through a larger hole in the side. I then took a piece of 4"x"4" piece of MDF, cut it in half, clamped the halves back together and drilled a 1/2' on the center.
|---0---|
2) Ran the cables through the big hole, then mounted my makeshift cable clamp on the outside, the hole filled by the cables. Next went silcone sealant into the hole.
3) The USB cable connected to a USB hub, which connected to the mouse and keyboard.
4) The VGA cable ran to a Sony 15" LCD.
That worked quite well.
I was also running a home workgroup on Windows XP Pro, so I set the PIII to remotely run my main recording machine, a P4 3ghtz. The Remote Desktop feature gives you the freedom to locate your booth and editing area away from each other, limited only by the length of a network cable instead of video and mouse cables.
For the mic and headphones, I built a couple of wallplates out of MDF with an XLR and 1/4 stereo jack on each side. Markettek or Redco Audio (http://www.redco.com/) have those items.
Good luck with the build.
The cheapest way to do this is to just drill a hole as small as possible, run the cable through, and then completely caulk up the hole so that your isolation is returned. It does mean that you now have a cable literally built into your booth, but cables are not expensive.
