VST Problem
  • Thread starter Thread starter Thomas
T
Thomas
I'm trying to incorporate a VST plug in. I stored it in a separate folder on the hard drive and specified a path to the folder from the application. When I click on DSP a pop up window appears "Error Opening VST Scan File". Any suggestions on what I'm doing wrong?
Nothing. What plugin is it? Maybe it's bunk. Have you tried other VST plugins? Also, are you at 2.2 yet? VST didn't work for me in n-Track when n-Track first started supporting it.
Slackmaster 2000
I think you nailed it Slack. I'm using the demo version of n-track, so that's probably the answer. The plug in I was trying to load is PSP Mixpressor which has been tested on the n-track application.
i'm using the demo version of n-track and vst plug ins work just fine. i put them into the n-track folder though.
