VST Connections
  • Thread starter Thread starter Atkron205
Atkron205
Atkron205
Member
When you set up an input buss, do you have to choose it for each new project? would it be best to set up one with 8 inputs to use everytime? Thanks
I save templates that work for each type of artist I am working with. For example I have a template for rock bands that has all of the tracks, inputs, group channels and basic effects already setup.
I create a template from a project I have already worked on and is already setup. 'Save as Template'. Then I will open that new template, delete all the audio files and the pool and re-save as template again so there is no existing audio in it next time I open.
I figured it out. from what little I know this program rocks, I also figured out the FX tracks and sends. the amp sims are pretty good. now for the metronome, can you not use it like a click track? is there a way to set it to say 120 BPM or does it always go by the project tempo? Thanks for your help.:thumbs up:
Not sure I understand your question. The click track is always the same as the project tempo. But that is variable...
You can change the tempo in the transport panel for a quick easy, but you can also create a tempo track. You can manipulate or create tempo changes throughout a track or project.
Then it gets more involved whether you are in musical or time based mode as to how that tempo related to the audio or midi/time based tracks... Much to learn and I still do...
Great to hear you are getting along well man. :)
got it, you can set the BPM in the tempo section, the metronome will follow this setting. Thanks!:D
I know it's off topic, but I see you're not using full screen mode for the mixer? Any reason for that (just because I'm curious)? :)
Actually the mixer is in full screen on monitor 3. I just have channel screen on the top portion of it. :)
Ah - fair enough! Mine doesn't display the windows bar (with the maximise/minimise/close buttons) when it's like that!
I think that has something to do with the multiple monitor setup I am using. That is just how it looks when I drag it to another monitor. And not sure if you are using Cubase 8. Things changed with this version.
