vs880ex
  • Thread starter Thread starter brent
B
brent
I recorded on tracks 1-4 no problem-- I go to track 5 and set up to record on track 5 in the same way that I have already recorded on tracks 1-4, then lastly I press the record button and then play and it does not go into record mode ( indicated by the still flashing red status button for track 5). I go to track 6 and run into the same thing. I have experienced this on every song that I have done on my vs880ex and it is not always the same track. I am stuck. I have had my recorder for 1 year and have not finished 1 song as a result of this problem. I will try anything ! Thanks.
Brent,
Press SELECT/CH EDIT for channel 5 or 6. Use PARAMETER arrows to scroll until you see CHANNEL LINK. Make sure it is off.
If that doesn't work, press SYSTEM under EDIT CONDITION. Use arrows again until you come to the last option, which is called something like INIT SYSTEM PARAMETERS, or something like that. (I'm not at my machine now) Press YES. This will return all your input etc.. routings to the default.
If you still can't get it to work, let me know, and I'll fire up my machine and post EXACT steps to take.
Larry
