reply to fanbagglia
Hello again.
I mentioned in another post how I use compression. I always use the onboard Dual Compressor for drums, bass and vocals. There is nothing to set, as it is an "Insert." If you are recording two tracks of drums or vocal, use the "Insert L" and "Insert R" function to acheive stereo compression. It works great. I have found that it really smoothes out the levels. If you have, for instance, drum tracks that were recorded without compression, but you wish like hell they had been, just record them to two V tracks, using compression, them move them to wherever they need to be. IG: Drums on V Tracks 5-1 and 6-1 recorded with compression to V tracks 7-2 and 8-2, moved back to 5-2 and 6-2. Then just use the 5-2 and 6-2 tracks in you mix instead of the original uncompressed 5-1 and 6-1. Just make sure you insert the compression into the play (Green) mixer function of the tracks playing back (to be recorded). If they are inserted into the input (orange) function, they won't record.
Also, do use the "Mixdown" function for final mix. There are a number of pre set choices that add compression, delay, EQ, etc. I often use "Rock Band" and "Bright Mix" but there are a lot more. It is an Insert for the Master block. it is on all VS880-EXs with 2.0 and above. It can be added to older machines by installing the new softwear available free on the Roland web page.
