volume match between A/D and digital multitrack recorder
  • Thread starter Thread starter Papoola
P
Papoola
Dear All in my production chainI Have several possibilities to level and match the volume. In order of flow:
1-Synthetizer volume out(no hiss at any level)
2-A/D converter analog in (green/red led)
3-Digital multitrack recorder input trim
4-Digital multitrack recorder master fader
5-Digital multitrack recorder track fader
I try to describe how do I set each of them and I would appreciate your guidelines how to proceed having the best use of the bits
1-Max
2-just below the red
3-just below the red
4-0 level
5-0 level
Now, come to the problem. Doing so the sound is completely distrorted and clipped. I can also visually check this because the multitrac recorder meter is out of scale (full clipping and above)
The question is where to reduce the level. The two logical places for me are at the A/D input or at the multitrack track fader.
Due to the fact that the digital conversion is done inside the external A/D (before the multitrack) I would choose to stay here at the highest possible level to use all the bits in the conversion process.
In this way I should reduce the track fader level of the multitrack to keep things undistorted.(it will work as a mixer only,correct??)s
Is this the right way or better options ??
Tks for the help
