Dark Imagery
Ok... I think I have a grasp on how sends, busses, and aux inputs work. But I'm having trouble wrapping my mind around the volume faders.
Say I have a snare drum routed through a send to a post fader bus. The bus is routed to an aux input (effect return? - I'm using protools) which has a reverb plugin on an insert. Tell me if I'm right - The volume fader on the bus determines the amount of the snare signal that routes to the bus. Essentially a wet/dry knob since the reverb plugin on the aux input is 100% wet. Right? Where I get confused is that there's also a volume fader on the aux input and I'm having trouble seeing how it fits in. Is it the volume of the actual effect? If I had the snare's bus turned very low and the aux input turned high would I get a very audible yet dryish reverb on the snare? Hope I'm not asking this like a 'tard bag.
Could somebody explain to me in a simple fashion the relationship between the volume faders on the busses vs aux inputs? Maybe an example of an end result having high bus volume/ low aux input and low bus volume/ high aux input volume.
Thanks guys!
Thanks guys!
