For reverb, I usually put a reverb onto Bus "A", all tracks routed, and setup the verb for no dry, all wet on the bus, then adjust the channel wet/dry sends to taste, I could never be happy with the "dry mixdown and add reverb to the whole mix" concept.
I usually don't want any reverb at all on my bass tracks, and sometimes none on the kick drum as well, plus a little bit more on the snare and just a touch on the drum overheads.
I also usually apply a bit more reverb to background vocals than I do to the lead vocal.
I will usually compress both the snare and the kick, the bass, acoustic guitars, and all vocals at least a little bit, usually not quite enough to hear it as an effect, but just enough to "tame" the peaks so that they are a bit more controlled.
As for EQ, for starters, you could try giving a slight cut to all guitars/bass/keyboards around 800/1200 hz, and giving the vocals a slight boost in the same area, just to get you started with the idea of "making a hole" in the music for the vocals to sit in, as you do it more and more, you'll develop different ways to get to the same place soundwise.
