sonatataster
So I've started out writing some songs in Live and I've been trying to record some vocals to go with the synth parts I've programmed but I keep running into the problem of not getting high enough levels on the vocals to compete with the instruments. I thought about just making the instruments more quiet, but then the final track will be too quiet (at least that's what I think).
Some background information: I'm using an AT 2035 condenser mic with a ZOOM H4 field recorder as my pre-amp/sound card (I know, but it's what I have). My vocal range is from G2-A3 (on a good day). It has a decent amount of nasalness to it and can be a bit thin at times. I don't usually use too much vibrato.
I've tried turning up the levels on the H4, but that made the vocals sound really harsh up in the high end, like the mic was overloaded, even with me moving further away from the mic. I've tried using the limiter in Live to bring up the levels on the vocals but that creates harshness too. I've tried using compressors and equalizers, but I'm not sure that I'm using them right.
I've poked around a bit and I'm wondering if the culprit is the equipment that I'm using or if it's possible to correct the problem using software. In terms of the equipment, I'd be more inclined to change mics, as I can still return it and get the full value, whereas the H4 wouldn't get me enough to get a decent interface, although I have a feeling that's going to be the only solution. Thanks in advance.
