lawrencepd, sondriven,
As bvaleria said, lead vocals are recorded mono panned straight up (most of the time). What he means on the backups (two or more) is to record them on seperate tracks in mono and then pan them left and/or right or what ever sounds good to you. There are know rules to how you do it. Listen to some Beatles, on some songs, the lead vocal is panned hard left or right and the backups are on the other channel. What ever sounds good. If you want to hear how the best does it again listen to what Sir George Martin did with the Beatles. Great lessons in mixing. Here's a good trick on panning in the mix. Close your eyes and listen to your song. Then as if you were standing or sitting at a show and looking at the band, pan things as they appear on stage, except for the drums. They should be panned seperatly. Pan them as they are set up on stage. Kick straight up, riding toms, a little to the left, floor toms, a little more to the left, snare, just off to the right, hihat, just a little more off to the right, the same with cymbles (left and right). You get the idea. Pan as you see the band setup looking at them from the front. Just something to try. You may not like the mix, but experiment.
Boardman
OldNewDam Productions
