Vocal tuning question
N
newbie956
is its possible to copy tuned notes from one vocal and paste those same note parameters into another vocal using melodyne or auto tune (graph mode)?
Not 100% sure of the question, but if I understand correctly, I would do this. Render out the corrected vocal track, then import it back in and cut and paste as required. Or, take the instance of the configured plugin, once configured and copy that plugin to another track. That will keep your configuration consistent across all tracks.
You want to copy how it tuned one voice, and then apply that adjustment to a different vocal? As in pitch correct Cher with Taylor Swift's? I cannot imagine any scenario where that would work, even if you could do it? I tried it incubase and I certainly can't copy and paste correction parameters?
What I mean is if I have a vocal recording in track 1 ....that I pitched corrected using auto tunes graph mode..is there a way to copy and paste the pitch corrected notes from track 1 (autotune graph mode) and paste them into another instance of auto tunes graph mode on track 2 where I have another vocal take?
But the mistakes in tuning would be in different places? No two takes would have identical placement or amount of pitch error?
I dont know if this is how pitch correction would work. If it saves offsets from pitch then it shouldn't work when putting that "profile" on another track unless the variations in pitch were exactly the same. If singer 1 is 20 cents off, and it saves that as +20 cents to get to pitch, and you apply that correction to a second singer who is 35 cents off, then it would result in an off pitch note.
If you're trying to minimize the CPU usage, just pitch correct track 1, freeze it, and then move on to track 2 and freeze that one.
