M
marciuxaz
Hi everybody, recently i found this technique. the main idea is that you need to set up vocal microphone and put a pair of small monitors about three feet on either side of the microphone.Then using a tape you need to measure distance between speakers and microphone to ensure that they are equidistant. Next, you need to place the speakers 90 degrees off axis and point them directly at the microphone. Then, you need to ensure that backing track coming out of both speakers is on mono and polarity on one of the speakers must be reversed. The vocalist will hear the speakers, due to the distance between his or her ears, but the speaker output will be 180 degrees out of phase at the microphone capsule.
I would like to know more about it. does anybody tried this technique and if so, does sound differ much from vocal recorded using headphones? what are the difference and what are pros and cons of this technique?
P.S. I apologize for my crappy English.
