Geez...small world! Yep, it's me! Yeah, I'm sure there are plenty of VM200 users out there that don't use Cakewalk! I am loving Sonar with dual monitor. I'm working the kinks out of the system now. Lately I've been chasing some static I hear during playback throught the PA. Part of it is a grounding issue. I've found that a large amount of the noise goes away when I plug the mixer into the PA, instead of where the PC is plugged in. Probably about 2/3 of it!
I'm also loving the flexibility that the Dakota has given me. I haven't ventured into the WDM drivers yet. I understand they just came out with a new Beta. I don't know if it cured problems I've heard about with Midi. I had read that they had issues with Midi, so I've held off, because I use the Midi alot...mostly for sync and controling the Mixer in Sonar, but when I am done, I will also have my 2 keyboards, a sound module and my Guitar Controller plugged in.
I did some recording on the VS-840 last weekend, then transferred the tracks into Sonar. Unfortunately, the VS-840 can only send out 2 channels of audio (digital or analog) at a time. However, using MTC, I was able to send them in pairs and have them be in perfect sync without further editing. That was the first time I'd ever used MTC... Sonar jumped right to the point in time that I had started playback on the VS-840. That was cool. I did have to delete all of the empty space prior to the music on Sonar, which was no big deal. It was a great learning experience.
Any luck with your Studioware panel?
