Vintage DBX 160 update
  • Thread starter Thread starter zradioman
zradioman
zradioman
Throbbing Member
Here is some info and pic for those who inquired
A justified classic from the Ford Motor Co of compressors, DBX. DBX VCA's have always been some of the best and are widely used -- in SSL desks for example. This box rocks on kit and guitars and great for percussive instruments. We've all had to suffer through the drummer who gets excited at the beginning of each new section of the song--you know, the genius who hits the kick drum 2 dB harder at the head of each chorus. Excells at controlling that excitement.
The dbx 160 has a tremendous amount of "grab," and when used sparingly, it can erase the dynamic range from almost anything.
Description: Mono
Metering: VU
Principle: Solid State
Connections: Jones type barrier strip
Controls: threshold, output gain, meter function, compression
Performance: max input level +21dB
distortion .075% 2nd harmonic at infinite compression at +4dBm output; .5% 3rd harmonic typical at infinite compression ratio
attack time 15 milliseconds for 10dB level change above threshold. 5 milliseconds for 20dB level change above threshold. 3 milliseconds for 30dB level change
release rate 120dB/second
compression ratio continuously variable from 1:1 to 120:1
threshold continuously variable from 10mV to 3V
Dimensions half rack
just $600/free ship
920-538-0769
zradioman2000@yahoo.com
thanks
It'll be on ebay in a couple of days if it doesn't sell here
question..
how would you rack this? standard empty rack?
