D Dopple New member Dec 12, 2003 #1 Is it possible to record onto more than 2 tracks at the same time? Maybe using the connections at the back?
jfrog uber-nerd Dec 15, 2003 #4 you can get around this by going thru a mixing board. Then you have as many channels as the board, which gets reduced to two channels and into the VF. That's probably not the answer you wanted, though.
D Dopple New member Dec 16, 2003 #5 Every piece of advice is appreciated. It's the only way I'll learn(leeching of others experience!) Thanks
