slide_blues
Tough choice on these two DAWs, I've been searching and reading threads for days.
The aw obviously costs more, and you get compression and 4 band parametic eq on each channel. The downside is the paired stereo tracks, which you must find a way to use without compromising the mix. The vf's 16 independent channels and faders eliminate this problem.
Since this is a Fostex board, can you help me decide by answering these questions? Thanks.
1. How do you get around the limitations of the eq on the vf? Outboard eq? Mix only on a PC instead? It just seems so handy to have what the aw has (independent 4 band para on each channel) - then you can hear how tracks blend with each other and react to eq during mixdown.
2. What about compression on each channel? It seems it would be handy to be able to compress each track independently rather than the mix as a whole?
Anyway, those seem to be the major differences between these two. One benefit of going with the Fostex is that I'm used to the way things work as I have a VF80 now.
