vf160 to Alesis adat
  • Thread starter Thread starter wepedstudio
W
wepedstudio
Well, I know one thing for sure, this combo is a little touchy
the adat is feeding my mackie 16x8. the adat feeds (optically) to the Fostex. I have been recording onto the vf160 but it seems to have developed a skip. like a cd skip or hesitation. i have reformatted the hard drive already
IS MY HARD DRIVE BAD :mad:? it said there was 364 bad sectors but never said what to do with them !!:eek:
Also, can i sync up the record 'botton' on both the Alesis and Fostex ? i mean, when i press 'record+play' on the Fostex... can the Alesis start recording at the same time simultaneously ?:confused:
The Alesis is slaved to the Fostex. I also need to get a computer hooked up here as well to run it all.:D
.......ANY SUGGESTIONS ?? Adobe Audition 2.0, fiber optic from out of Alesis TO pc sound card ???
Sounds like a clock/sync issue. Is the ADAT feed set to 44.1kHz?
Paj
8^?
Yes. 44.1 analog. I believe it's analog from the Mackie. Also, it says not to run both {in/out to in/out} only out fiber optic ADAT to in optic FOSTEX so as not to create noise loop. And it will do just that. I plan on slaving to a designated computer drive for back up and mixdown soon.
I guess for now I'll just hit REC on ADAT then REC on Fostex. Manual work.
And I have the question of Fostex to PC. Can I run fiber optic out FOSTEX to a PC card? Or my ADAT to PC card? I really need suggesstions here.
I have determined that Fostax hard drive is bad and have ordered new one.
