mark4man
MoonMix Studios
Having a great deal of trouble with the VF-16 S/P DIF Optical Out, as related to transferring tracks into my PC multutracking software (Cakewalk Pro Audio 9) via my new PCI Interface, Echo Audio GINA 24. The ADAT system is working fine, but S/P DIF Digital Out is causing a serious overload with the GINA.
First, my connections are as follows:
VF-16: Selected S/P DIF as Digital Out. Toslink Optical cable attached to Digital/Data Out.
GINA 24: Digital Mode Switch set to S/P DIF Optical. Toslink Optical cable attached to Optical In.
Regardless of where the gain controls are set on either device (+4db, -10db...even with no signal present, i.e., gains on both machines all the way down), I experience a loud, scratchy buzz; & the input meters are pegged. I know both of these hardware peices are pro audio caliber, should interface easily; & that this problem has to have a logical solution...but I sure can't seem to figure it out right now. Can anyone with any knowledge of one or both of these systems please help out. Thanks in advance.
Sincerely,
Mark Forman
Sincerely,
Mark Forman
