8
8Ball
I have a Fostex VF-16 and when i try to bounce the tracks down or "Ping Pong" record them i cant get the effects to work. I set everything right. I'll tell you exactly what i do:
1. I press the input select button. and set it so that channels 9-16 are green.
2. I press the Buss Source button so that it is green. I then press the tracks i want to mix down.
3. I then press the Buss Record button and select channels 15 and 16.
4. I then record. While it's recording I turn the volume up on some parts and down on some parts. And then I turn on some effects on. So on some harmony's I'll turn the effect up and on some solo's I'll turn it down. And obviously it's playing while it's recording so i can hear the effects working.
5. When I listen to the finished version, none of the effects were mixed down. The volume adjustments were mixed down but the effects weren't.
Please tell me what I'm doing wrong. Thanx.
