M
michaelq
what exactly is FET impedance conversion? i'm trying to build my own condenser mic using an old tapeop article found at http://www.prosoundweb.com/recording/tapeop/buildmic/buildmic_16_1.shtml ...one problem is that the mic cartridge suggested is now obsolete. i called digikey and they gave me "similar" options, but with one the frequency was from 100-10khz, and the other 100-15khz. the 100-10 khz seems to be cutting too much out of the high end, but apparently that one does have an internal FET impedance converter. (not sure about the 100-15khz but on digikey the # is 359-1011-nd ) as stated earlier in this post i do not know what FET impedance conversion is so i dont know how to make an external one if needed. if anyone can explain a. FET impedance conversion or b. have any suggestions for omnidirectional mic cartridges with ranges preferrably close to 20khz (or even places to look other than digikey) it'd be appreciated. thanks in advance. -michael q
