junplugged
Taking the slow road
i'm seeing this on some mic preamps. is it only for efficient energy transfer, levels, and hum eliminination or also audio control?
junplugged said:variable input impedance - does it alter the sound??
Then let me expound some more...rsolinski said:short answer.....yes
Ray
MOFO Pro said:Then let me expound some more...![]()
If your tranmission medium has an impedance of say 600 ohms, and it terminates on a connection rated at the exact same 600 ohms... all of the energy is absorbed by the termination (or input). If the termination doesn't match the impedance of the transmission medium, the energy that is not absorbed is reflected back in the reverse direction or the transmission medium. (The amount of reflected signal depends on the degree of mismatch). As this reverse signal energy meets the forward stream it mixes... if the signals meet in phase with each other... they are additive and you will see a boost in these frequencies... If they meet out of phase... the frequencies will be cut... If two equal signals are combined 180 degrees out of phase with each other, theoretically, they would completely cancel each other. These reflections though, are at a much lower amplitude to forward signal so the result is not so pronounced but the affected frequency band is attenuated.
junplugged said:i'm seeing this on some mic preamps. is it only for efficient energy transfer, levels, and hum eliminination or also audio control?
Robert D said:Spot on, MCI.![]()
Well I was talking off the top of my head... (might as well have been out of my ass though)boingoman said:Yup, good find. Let's give credit, though. That was written by Rob Jones at Focusrite a few years ago. (I though it sounded familiar)
MOFO Pro said:Thanks for the spanking![]()
junplugged said:this gets me thinking, wondering about how the extremely low frequency audio signals are picked up and converted into electrical signals by the mic electronics, i guess there is a higher hz electrical signal, that is modulated by the variations of the audio by the capsule. i'm probably thinking in radio terms....
