C
conman013
I figure this would be the best place to ask this question as most of you would know all about sound proofing and such.
I just bought a set of Roland TD-9S electronic drums, and just recently i've gotten a complaint from the tenants that live directly under me about the thumping coming from the hitting of the pads vibrating through the rack and on the floor, and from kicking the kick pad. Mostly from the kick pad though. I am looking for a solution to eliminate this without having to relocate my electronic drums.
One solution I came up with was to lay four cinder blocks on the floor with a thick sheet of plywood on top to raise the drums off the floor. Would this work? I am thinking that because vibrations can't travel through air, they would just dissipate through the plywood and therefore stop the thumping on the floor and keep peace with my neighbors below. Or would the vibrations not dissipate enough and just travel down the cinder blocks and back through the floor? Maybe add some rubber between the plywood and cinder blocks if this happens? Any other suggestions? Thanks in advance!
