utilizing 24 bit in CEP 1.2
  • Thread starter Thread starter secretorchard
secretorchard
If I go to Options:Settings (F4) before opening a new file in edit mode, I can see that my sound card supports up to "24 bit packed," as well it should. Now..when I go to open a new file by File:New, I get a small menu of options for the sample rate (44.1 kHz), whether I want it to be a stereo or mono track, AND the resolution, under which I have the option of 8 bit, 16 bit and 32 bit float. Ok folks...how do I record in 24 bit, as my sound card supports? Pretty elementary question, huh?
Select 32 bit float. Cool operates in that (which is better for internal processing than 24 bit), and if you need to send a 24 bit wav out, you can convert it before you do so. Otherwise, you'll convert your 32-bit files to 16 bit before burning to CD.
The 24 bit packed option is what Cool will convert the 32-bit file to *if* you do the conversion. Otherwise, it'll happily operate at 32 bit float. I bet your soundcard won't have a problem with that - mine doesn't. :)
this is whats happening.. if your card is anything like mine...
INPUT... a 24-bit word comes in... CEP adds 8 bits of zeroes on the end. At this point the file is technically still a 24 bit sample....Then.. once you make any adjustment in CEP (volume, whatever...) it suddenly becomes 32bit... with any rounding errors in the last 8 bits.. keeping your 24 bits pure.
OUTPUT.. if you are playing back an UNMODIFIED 24-bit sample... it is unmodified... if you are playing back a 32-bit sample.. your card TRUNCATES the last 8 bits.. delivering a 24-bit sound to your amp (which then degrades it to, like 4-bits j/k)... and there you go. The chopped 8 bits generally represent all of your error.. but some is introduced since youre chopping it. (for instance a .....49 becomes ....40 instead of .....50, only in binary.. not base10)
OUTPUT PART 2... when you dither down 16-bit... normal dithering problems apply... but generally its better than chopping.
xoxo
