D
DHN
Just curious if any of you are using a mixer along with your MD8. I use the 1642VLZ. It has 8 direct outs, post EQ/Fader and great mic pre amps. For play back, I connect the MD8 directly to my power amp and listen through monitors. Can you think of any advantage using the direct outs of the MD8 pre EQ/Faders to connect back to the 1642 for play back? The reason I ask is that during recording, you have to disconnect the direct outs from the MD8 to the mixer because it creates a problematic loop. It's a little troublesome to connect and disconnect all 8 direct outs between playback and recording.
DHN
DHN
