Using pads on SR18
  • Thread starter Thread starter kimbara
K
kimbara
as you can assign songs to the pads for quickness of use, my problem is when you select and play them from the pad they play at default tempo and not the desired tempo, can you assign songs to pads so they will play at the required tempo???
many thanks in advance
kim
kim
Kim - you should be able to set that as follows:
Press the System Setup button, page down (or up) to page 9 (Tempo), change setting to PERPAT
Erich
