A
asv
Many people say it's better to mix using monitors instead of good headphone.
Is that right? and why?
I just received my AKG K271 headphone yesterday.
It's lacking bass. but great on the upper mids and treble
Any idea how to monitor my bass level using this headset?
EQ your master output using a reference track until it sounds how you think it should sound. Mix, and then turn the EQ off before bouncing. That's what I do. Pain in the arse but it's better than guessing.
Alright thanks
What's 'reference track'?
I'm using 'reaper', i dont think i can put EQ on the master output volume? can i?
Eqing by ear is still guessing.
Headphones are good for checking mixes, not mixing mixes.
Cj
It's a bit less of a guess.
Once you EQ your headphones to a reference track, so that the ref track sounds how you think it should, then you should know how your mix should sound. It should feel more natural in the process. This would be opposed to mixing away and having to keep trying to remember how it should sound on those headphones.
Having said that, both ways are good. Learn the headphones. And, no matter whether it's speakers or headphones, where you are, how well you know the system, you should ALWAYS keep checking your reference, just to keep yourself on the right track.
I dont agree...you can do quite a bit of the mixing task if you are used to your headphones sound and you check back on monitors as much as possible...
its not ideal, but being a homerecorder seldom is
