Using effects from my rack with DAW
  • Thread starter Thread starter PatBrown
P
PatBrown
Ok my daw studio is all set up and I have been tracking very successfully. My question is:
How can I add effects from processors in my rack? I want to be able to send recorded tracks to my tube compressor, digital reverb, Antares A1 ect. How can I do this with out creating a feedback loop?
I would think you can set the track(s) that you want to add effects to to a specific output on your interface into your rack, then record the output of the effects onto a separate track in your computer. You didnt mention what interface or software you are using, but I would think you could select the output channel and setup the input monitoring in your software so that you dont create a feedback loop.
Piece of cake.
Put an insert on a channel/track in your DAW and assign that to a physical I/O on your breakout box/interface.
OR
You can create an aux channel/track with the insert and have that track's INPUT as an internal BUS inside the DAW. Then, for every track in the DAW that you want to use that effect on, just give that track a BUS Send to the BUS Input of the Aux track.
Get it?
Let me know- maybe there's a better way to explain it.....:D
