shawn0821
I am trying to use my line 6 pod and I just can't get a good sound out of it. If anyone can help me please do.
Define "good sound". I've gotten dozens of "good sounds" out of Pods. Of course, I never use presets for anything other than a starting point.
You will have to get more descriptive to get much help with this problem.
What type of sound are you looking to get? What type of guitar do you have? What have you already tried?
I think what he's saying is that he can't get a good recording with his POD, not the sound he gets with a POD as it is.
At least I hope that is the case.
If you're routing your POD's line-out into some build-in soundcard of your PC's motherboard everything would sound like crap, full-stop.
I think that's a rather a presumptuous statement. It might not yield as good results as a dedicated recording card, but to just outright say it will sound like crap may be a little rash.
And that's the other major component of good tone; good playing. Nice job?I have a few clips up on FrugalGuitarist.com (click on the "Issue 2" tab) of the Pocket Pod which has the same engine as the POD 2.0. I thought it sounded good and was capable of a wide range of tones. What guitar are you using?
Depends on a motherboard, but that was the case with all of the 4-5 PCs that I've owned. Depends on music as well - clean sound they might handle.
With my distortion, all the tracks look like a seismograph's scale in the eruption zone![]()
It actually sounds best when plugged into a tube power amp, like a mesa 90/90.another sound thing with the pod, is if your using an amp.
seems a person would want to use a solid state amp as the POD already has done the "tube simulation"....a tube amp would be doubling the tube-sound.
using a tube amp and having the already "tube simulated tone" from the POD might make it too tubey...or is that spelt tubie...to be or not to be. I flunked English.
the solid state amp doesn't color the sound as a tube amp will with its harmonics and all that, so seems a solid state amp will be a better fitted for the POD (if using the tube amp simulation stuff).
so farview, thats using the POD just for the effects and eq, and gate, and compressor only?..into a tube amp. makes sense.
in other words once the amp sim is turned off, is all the cabinet sim disconnected (internally)? the left knob, with all the amp selections is in operable or is the user supposed to set it as "clean" for the amp setting?
and is the speaker cabinet removed form the internal-sim-chain?
I've not read the 97 page manual yet...![]()
That's not what I said at all.so farview, thats using the POD just for the effects and eq, and gate, and compressor only?..into a tube amp. makes sense.
No, the CABINET sim is turned offin other words once the amp sim is turned off,
I'm still using the amp simulation, the amp is a POWER amp, not a guitar amp.is all the cabinet sim disconnected (internally)? the left knob, with all the amp selections is in operable or is the user supposed to set it as "clean" for the amp setting?
That's the only thing I turn off. There is a setting called "power amp stack" that I use that is voiced just for this purpose.and is the speaker cabinet removed form the internal-sim-chain?
