V
vinyvamos
Hi guys,
I'm currently looking for an alignment tape for my Otari MX70 1" 8 track but simply cannot afford to buy one new from JRF. I might be able to get a 41J326 tape 2nd hand quite cheap but will it work ok on my machine? (pending the tape's condition). This tape is made for the "denser" 1" machines (16 & 24 trackers) whereas mine is an 8 track "pro" machine. I will be using RMG SM900. Will the 41J326 tape at 320 nWb/m (+4 DIN) be ok for this tape and for the MX70?
I am relatively new to tape recording and this will be my first go at aligning a machine. All the machines I have bought had elec. problems to start with and have fixed them so I'm not afraid of a scope and PCBs full of pots ;-). The other problem is, I don't have much time before the first session for aligning this machine! Is there any easy way of testing the machine to see whether it is far off alignment? The tapes will only ever be used on my machine so I assume as long as it plays back at the same levels (@ 100Hz, 1K, 10K) as I had recorded then I should be ok??? The first session is a dirty 8 track-only punk session so a little bit of wobble might not be noticed.
Any advice you guys have would be much appreciated! Thanks!
Vinny
Vinny
