moskus
The Creator of Æ, Ø and Å
¨postalblue said:in sonar you can automate an effect without having to use the aux buss, can't you? so much easier indeed.
Easier, oh yes! But the clue is (at this moment) you can only automate the original Cawalk Dx8 Effects, the effects names starting with FXAndthename, such as FXChorus: These to be exact http://www.cakewalk.com/hf/images/SR_DX8.jpg.
Apply one effect to an audiotrack. Rightclick on the track in the TrackView. Select Envelopes -> Create. And on the bottom at the new menu you will see the name of the effect, and select it. It will show you a menu of what automation envelopes you can create. Select the one's you want, and go wild!
Tech help: http://www.cakewalk.com/tips/techtipsept01_1.html
And the promotion: http://www.cakewalk.com/Products/SR/DX8.html
