L
Laimon
Hi everybody,
I am planning to buy a not-too-expensive external sound card for a spcific purpose, which I am gonna explain in the following.
I play guitar, and I have been using a lot of different loopers in the years. I don't use them live, only at home as composition tools. Unfortunately, I find that physical loopers have often shortcomings; in particular, I recently turned to a MIDI system in order to control my increasingly complex setup, and restricting the field of viable loopers to those that are midi controllable really narrows down the choice to 3-4 (I am serious!). These are not only expensive, but also often suboptimal, for lack of this or that function.
Then I thought: maybe the solution could be to use some PC looping software (I am leaning towards Ableton Live)! What I need then is an external sound card that can send, via USB or Firewire, audio (input and output) and MIDI (to control it with my pedalboard). I already have an internal sound card (E-MU 1212m PCIe) which has nice AD converters and midi input, but I would need always to unplug one of the speakers to get the return signal, plus I'd have to run a bunch of cables of like 4 meters across the room, so I really prefer to find a decent minimal sound card to place with my equipment and use it only for that.
So now, to the questions:
- what would you guys recommend? I need at least one level input and level output (well, that is quite standard), and MIDI in/out, and I would like actually good converters
- should I go USB or Firewire?
- how long can the cable be before I run into latency problems? I need at least 3 meters...
Looking forward to any suggestion you might have!
Cheers,
Simone
Cheers,
Simone
